Home > Maintenance & Mods (L322) > Need to replace drivers door lock assembly...
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Anybody got a link to detailed instructions re this? Ta. QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #424958 26th Jan 2017 9:27pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
There's some information about this in the wiki, but basically, the door card off, you tubes your buddy for details, move airbag cartridge, peel the horrible sticky stuff back, release cables from lock, then the door lock button, and the cental locking connector, undo 3 or 4 torx head screws remove lock, and replace with new one.
That's about it.
Good luck.
if you are careful, you can release the puddle light bulb connector, and stand the door card inside the door opening without disconnecting the window switches, as a lot on here, including me, had problems with them after.
Wink
Post #425006 27th Jan 2017 7:53am
gregdav
forgot to say. give your new lock a damn good greasing, even though it appears to be done.
they get a lot of water on them.
Post #425030 27th Jan 2017 10:30am
''a damn good greasing''
said in a posh voice..... Mr. Green
Post #425069 27th Jan 2017 3:30pm
gregdav
Laughing Laughing Laughing Thumbs Up
Post #425088 27th Jan 2017 5:39pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
And whatever you do, don't start the job with the window down, remove the airbag then turn the ignition on to raise the window which shouldn't have been down in the first place. That would give an airbag fault light.
Only an idiot would do that ...... Rolling Eyes
Post #425091 27th Jan 2017 5:53pm
