Home > Maintenance & Mods (L322) > Rear LED relay
ruffy
Rear LED relay
Morning all, a quick question if I may (I have searched for relevant posts but can't find one that covers the key issue). The previous owner has fitted the later LED lights (2010-on I think) and although I get the usual occasional flicker they seem to work well apart from the NSR fog light. I get the 'check rear fog light' message when I start up and only the OSR works; I queried this when I bought the car and was told it was just because they were LED lights. I have recently had some other work done and it was found that a relay for the NSR is missing, i.e. there are 4 loose wires with spade connectors on the end. Will this have been deliberate so the lights work? If I simply replace the relay will the NSR fog light work without affecting the operation of the lights as a whole? Thanks. 1982 SIII 88” diesel
2007 Discovery 3 V8 S
All gone: 2007 Overfinch TDV8
2007 Supercharged
1991 Vogue SE 3.9 V8
2000 Defender 90 Td5
Post #424840 26th Jan 2017 10:01am
would it be easy for you to swop the off side box to the near side and check if it all works ok....if so it will a matter of obtaining a similar one ..
Post #424841 26th Jan 2017 10:17am
alistairh
If the fog lights not right they probably haven't wired in a ballast.. I've just fitted a set and they worked plug and play apart from warning messages on dash and fogs being half on.. simply wired in resistors and ballasts and their perfect...
Post #424842 26th Jan 2017 10:18am
ruffy
Thanks for the quick responses. Swapping the other one over is a good shout, however I don't know which wire is which as they're not marked - will I do any damage with the 'give it a try' approach?? Don't know anything about resistors and ballasts, all I can say is the lights work fine - apart from the flickering mainly on start up and the one fog light obviously. A new relay costs about 5 so not much outlay if it solves the problem. 1982 SIII 88” diesel
2007 Supercharged
Post #424852 26th Jan 2017 10:46am
