Home > Technical (L322) > ticking noise inside cabin
bogie
mine ticks/buzzes behind the aircon control area too ...usually notice it when I first get in, then seems to go away
almost as if something is warming up before I start the engine Smile cheers
bogie
Post #42464 16th Dec 2010 8:53am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
That one behind the air con buttons is a small fan. There is a small vent to the left of the buttons for the vent control.
The Other one the OP can hear is the sound of depreciation, you get used to it after a while Crying or Very sad 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #42479 16th Dec 2010 1:54pm
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
the ticking noise when running is not there when the temp is above -2 degrees but at -3/-4 degrees it's there all the time.
it's on all the time the preheater is on also
startstone MK have heard it but say they or LR have never seen this before and are looking into it Shocked
Post #42561 17th Dec 2010 11:20am
