![]() | Home > Technical (L322) > Activating park heating |
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 ![]() ![]() ![]() |
Hi. I got a 2003 td6 and activated the park heat with the iidtool. Its gone 2 weeks and the option for park heat has not shown up at the nav control.
Matcossy Member Since: 14 Nov 2016 Location: Derby Posts: 6 ![]() ![]() ![]() |
Have you tried a battery reset? |
Hi That did the trick. After the battery reset the option to acitvate park heat turned up. Anyway, Iw got the remote and the reciver but cant find the cables to connect the reciver to. Had a look behind behind the rear fuse box, but nothing there. Can i wire this my selves. Iw looked around but cant find a guide for this. Does anyone know? -03V td6 -72 Cadillac Coupe DeVille 7,7liter. |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hi , im doing this at the moment , you need the t90 receiver and an aerial. The wiring loom is present. 2015 4.4 AB
