Home > Technical (L322) > Air Suspension Valve Block
Jacckk
2010 Range Rover Autobiography 5.0 SC V8 Mariana Black
Hi,
The air line that goes from the valve block to the reservoir on my 2003 has been damaged. Does anyone know if you can buy just this line?
Secondly the rubber mounts for the valve block seem to have gone hard and broken so it's just hanging by the pipes. Is it possible to get new mounts for this?
Thanks.
Post #424334 22nd Jan 2017 10:07pm
1. Yes. If memory serves me correctly it is standard 6mm airline
2. Don't think so, comes as a part of the valve block. I had the same problem with the valve block on the reservoir, somehow managed to rig something up to make it stay put. Might try Dan at Duckworths though? .
Post #424348 22nd Jan 2017 11:13pm
