Home > Technical (L322) > Folding Mirrors
bishbosh10
Folding Mirrors
Is there a way to change the programming so the mirrors only unfold when the engine is started? Seems a waste of effort having them unfold each time you unlock the doors, after all, you don't really need them until the engine is running do you? Unless you are doing some sort of clandestine work maybe......? Shocked Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #424232 22nd Jan 2017 12:27pm
no there isn't but you can switch it off and go 'manual' ...
Post #424236 22nd Jan 2017 12:37pm
CS
If you fold them using the button beside the window before you switch the engine off they don't fold out again until you press the button again, I don't know any way you can link it to the engine being on, indeed that would be inconvenient if you need to fold them in to get in/out of a single garage. Only Range Rovers since 1988
Post #424321 22nd Jan 2017 7:58pm
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Is the auto fold only on later models or do I need to program? Mine is a 2008
Terry 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #424393 23rd Jan 2017 9:54am
MrSkill
Stan - how do you change to manual ?
Post #424423 23rd Jan 2017 2:29pm
cancel the folding bit with an iidtool and then just use the button on the drivers switch console..
Post #424428 23rd Jan 2017 3:37pm
Mr Tee
It's in the menu between the dials IIRC
Post #424430 23rd Jan 2017 3:45pm
the dip function is but not the folding part...[might be wrong though]
Post #424431 23rd Jan 2017 3:59pm
