Home > Technical (L322) > Engine bay noise |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
sounds normal, unless the noise is very loud.. |
18th Jan 2017 9:10am |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
It's not overly loud. Never noticed it before so it kind of threw me. |
18th Jan 2017 9:14am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Could be the cooling fan insidd the ecu box. |
18th Jan 2017 11:08am |
Seems to have gotten louder.. it only starts when the keys in position 2? Sounds like its coming from the front of the engine? No errors being read by iid (yet
19th Jan 2017 7:10pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Have you listened next to the big black box at the left hand side of the engine bay looking from the front as these fans can fail? Do you have your heater turned off as there is a coolant pump on the nearside inner wing next to the heater valve? maybe the aircon condenser fan is having a funny turn.. |
19th Jan 2017 10:25pm |
Hi mate. All quiet in the ecu box and heatings off.! It sounds like it's coming from within the engine, possibly the throttle body? Shall get a better look/listen in the daylight.. |
19th Jan 2017 10:53pm |
20th Jan 2017 6:40am |
That's weird ! |
20th Jan 2017 7:31am |
I was correct .. unplugged this and noise stopped..I can hear what sounds like the throttle body opening and this annoying whine which has gotten louder..my idle under 1000rpm is still slightly unstable, I wonder if it's linked??
20th Jan 2017 4:06pm |
Seems like it may be normal, think this thread is linking to the same engine.
20th Jan 2017 5:19pm |
That's the thread I've been reading at least with the m62 you have the option of posting on both land rover and BMW forums to trouble shoot lol..I've got new plugs to fit shortly then will check the coil packs at the same time.. maf and o2 readings are within range so hopefully nail it shortly... it still pulls like a train and drives great so not the end of the world.. cheers for input buddy.. |
20th Jan 2017 7:31pm |
yep definitely useful sharing the mechanicals with the Bimmer crowd, they are even more nuts than RR owners (maybe) and dhon't shy away from getting the spanners out |
20th Jan 2017 7:51pm |
