Home > Technical (L405) > Traction control issue in cold weather |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35339 |
my L322 does that and i've read that earlier FF's also stay in lower gears when cold.. |
18th Jan 2017 10:15am |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
^^^^ same here Regards
18th Jan 2017 10:21am |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 404 |
Did this to me for about an hour this morning on mixed A roads and town driving...very irritating as I'm sure it's not meant to do this. |
18th Jan 2017 10:47am |
a hour seems a bit to much , mine gets going after 5 to 10 minutes..... |
18th Jan 2017 10:56am |
WillyT Member Since: 12 Aug 2016 Location: UK Posts: 90 |
Isn't this the Auto Terrain Response sensing the temperature and reducing power ?
18th Jan 2017 12:25pm |
peekay Member Since: 07 Nov 2011 Location: London Posts: 91 |
^^ think it's this.
18th Jan 2017 7:31pm |
My main dealer service receptionist wasn't aware of this possible cause so I'll try this fix in the morning as it looks like it's going to be another cold one.
18th Jan 2017 7:48pm |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 |
AndyS
18th Jan 2017 8:40pm |
Nick
18th Jan 2017 10:04pm |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
I am pretty convinced that it is the Auto Terrain Response putting it in Grass/Snow mode. I notice it when the weather is below about 3degC. If you press the ATR rotary control when it is sub-zero but look at the dash display, I'm again fairly certain that you briefly see it switch off from Grass/Snow mode. |
18th Jan 2017 10:27pm |
If that is the case then use the terrain response tab on the 4x4 info screen to check before disabling the auto function
18th Jan 2017 10:40pm |
Did it on my car this morning. -3 outside, pushed the centre ATR knob and on the dash it said Grass, Gravel, Snow before switching to Off as it went into manual mode.
19th Jan 2017 8:14am |
Typically my car behaves itself this morning despite being -1dg but I'm watching it and will report back when I've been able to identify if the ATR is the culprit. |
19th Jan 2017 1:57pm |
-1ºC here too.
19th Jan 2017 5:12pm |
