Home > Technical (L322) > Air leak? |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 |
Ok here goes. Thus may be quite a long post but I want to give as much info as I can in order to get the best responses. I apologise in advance.
18th Jan 2017 7:02pm |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hi,
18th Jan 2017 7:10pm |
Interesting Simon. Thank you for the information. |
18th Jan 2017 7:17pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
and may possibly be "before" the valve block, which is why you get no height drop. .
18th Jan 2017 8:09pm |
Joe, just read your write up from aug 2014 about the reservoir and valve block removal. Great info by the way. Mine is a 2006 so will it be in the same place? Is the valve block under a cover just behind the drivers side front wheel, just inboard of the sill? If so this is where i think the hiss is comong fron. When i first looked, i thought this cover was one of the fuel pumps. Cheers. |
18th Jan 2017 8:56pm |
Found the air leak this morning. It is actually the reservoir! New one on order from Dan. Let's hope it's as easy to swap as it looks. Thanks for the thoughts, they did lead me in the right direction. |
19th Jan 2017 11:25am |
