Home > Maintenance & Mods (L322) > Help! Water coming into cabin
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
When i park my Range Rover pointing downhill and it rains I get water coming in.
Yesterday it seemed to be dripping from around the rear view mirror. Today from behind the liner at the top of the windscreen on drivers side.
If I park pointing uphill no water.
Is this possibly because my front sunroof drain holes are blocked?
If it is, how do I unblock them?
I've tried with thick strimmer wire and cat 5 cable. But going from the sunroof end I can only get the wire in about 10cm.
Any help gratefully received.
Thanks in advance for any help.
Post #423036 16th Jan 2017 12:17pm
..or it could be the tailgate seal and the water running down to the front...blocked sunroof drains are a common problem, for solutions do a forum search ..
Post #423038 16th Jan 2017 12:21pm
GAC23
Thanks, Stan.
Probably a stupid question ...
But if the tailgate seal is broken, wouldn't I get water in the boot when parked the other way round?
Post #423041 16th Jan 2017 12:28pm
have you checked the wheel well and in particular the electronics in the near side cubby.....it might be the sunroof drains as you suggested but tailgate seal is a common problem ..
Post #423044 16th Jan 2017 12:33pm
GAC23
I haven't. But I will.
Is the theory that if they're not wet, it's more likely to be the drains?
Post #423045 16th Jan 2017 12:34pm
probably Thumbs Up
Post #423047 16th Jan 2017 12:37pm
GAC23
Understood Smile
Thank you very much for your help.
Post #423048 16th Jan 2017 12:40pm
