Home > Technical (L322) > wheel nuts
Dolphinboy
wheel nuts
post deleted. (by mistake)
Post #42223 13th Dec 2010 9:47pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
They are RRS wheels and are for 05 - 09 MY vehicles so I believe that you will be fine using your black wheel nuts.
The full part number is RRC500261MNH and the only other point to note is that these wheels are not to be fitted to the Supercharged variants.
If the nuts don't fit then the RRS nuts are under a part number RRD500290 (you need 20 @ £5.68 inc VAT) and locking wheel nut set under part number RRB500120 (you only need one of these @ £39.82 inc VAT)
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #42227 13th Dec 2010 10:10pm
Dolphinboy
Thanks Steve. I have identified them as being 2006. Will I therefore definitely not need the silver 2006-on nuts or is that just for FFRR wheels and the RRS ones will be fine with the old 2002 black ones?
I had the tyre man put one of the new wheels on for me yesterday as the original had a split. As he didn't have any probs getting it on I take it they are ok?
PS Sorry I deleted the post by mistake whilst trying to edit. Not a good night so far! DOH! Embarassed
Post #42233 13th Dec 2010 10:20pm
stevegt
Just been back through the parts catalogue. Yes there are definitely RRS wheels but you will need the new nuts from the part numbers I gave you. Sorry for the confusion...
It is quite pricey for the nuts from LR so maybe you could try eBay, I have seen a set of 20 for about £35 recently. Not seen any locking nuts though.
Post #42235 13th Dec 2010 10:23pm
Dolphinboy
Steve you're a diamond! Will get on Ebay now. thanks very much for the part numbers. Thumbs Up
Which of the part numbers shall I go for - the RRS ones?
Post #42236 13th Dec 2010 10:26pm
stevegt
they are the same part number for both RRS and 06MY onwards FFRR.
Post #42239 13th Dec 2010 10:28pm
Dolphinboy
Steve, sorry to be a pain but these have a different number (590 instead of your 290)
http://cgi.ebay.co.uk/Range-Rover-Sport-Al...859wt_1141
are they going to be ok? I searched using your number but got no finds.
Post #42241 13th Dec 2010 10:37pm
stevegt
Just checked the part number for you and to be honest I'm not sure. They are listed as 08MY onwards for both RRS and FFRR.
Off the top of my head they are the same size as the previous MY nut (23mm) so I don't know what the difference is.
The advert does say that they fit all RRS models. That to me means that they will be good for your new wheels as it is the nut size and wheel that is important not the actual vehicle.
I would buy them and if they are not right send them back as it clearly states that they should be.
Post #42243 13th Dec 2010 10:46pm
Dolphinboy
No, you were right first time. Think the ones I saw are wrong and for 2008.
found this on google:
Part No: RRD500290
Dimensions: 0.13 m x 0.04 m x 0.15 m
Weight: 0.13 kilo
Supersedes: RRD500042
Fitment information for: RRD500290
Model Engine Year Qualifying Text
RANGE ROVER 02-09 All 2006 - 2007
RANGE ROVER 02-09 All 2008 - 2008 > 8A265240
RANGE ROVER SPORT All 2005 - 2007
RANGE ROVER SPORT All 2008 - 2008 > 8A130279
Post #42248 13th Dec 2010 11:25pm
stevegt
just done a search in microcat for the part number RRD500042 and it isn't recognised.
The part ending 590 is the nut used on both RRS & FFRR 10MY
Post #42249 13th Dec 2010 11:38pm
Dolphinboy
Brahmer!! Will get some tomorrow. THanks for al your help. Really put my mind at rest! Thumbs Up
Post #42251 13th Dec 2010 11:45pm
stevegt
No problem, happy to help
Post #42252 14th Dec 2010 12:09am
Dolphinboy
Got a set of 20 for £50 off ebay in the end. Pray they are the right ones!!
Post #42305 14th Dec 2010 4:08pm
if they are with a 23mm shank then they are the correct ones ..
Post #42307 14th Dec 2010 4:13pm
Dolphinboy
bought these in the end - they are 23mm shank I hope
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...1661wt_907
Can't wait as the tyres are fitted with good Wrangler M+s so I won't need to fork out £800 on winter tyres!! result!! Very Happy
Post #42349 14th Dec 2010 11:32pm
