Home > Maintenance & Mods (L322) > [SOLVED] TD6 Coolant Leak Engine Side - can't find it?
Developed a coolant leak this week, @ 1 litre per 100 miles (sets off Low Coolant warning)
Undertray had lots of coolant and subframe covered in drips.
With top cover off engine, and fan shroud removed (not had the fan fitted for @ 5 years) ran the car up to normal temperature, then switched off. Regular drip coming from bottom of crankshaft pulley, and another drip from the radiator bottom hose (coolant running down the underside). Ah, water pump or thermostat housing?
Out with the inspection lamp and mirror, really no indication of any leakage above the crankshaft pulley from either the water pump or the thermostat housing, so a bit mystified as to where the problem is. Can the water pump leak from other than the seal/gasket? Don't really want to start taking it all apart until I figure out the problem. It is the original water pump (afaik) so it could be reaching the end of its useful life and about the spectacularly die on me? Took the tension off the drive belt and there is a fair amount of wiggle on the water pump. Also hoping it is not head gasket!
Europarts offering Circoli or Airtex water pumps @ £60, or should I go for LR ? Will probably replace the thermostat and the drive belts while I am at it. .
Post #408272 8th Oct 2016 11:13am
Dolphinboy
Hi Joe, if your water pump has a lot of wiggle it will be the bearings going. It's only a matter of time before it implodes and wrecks your Pulley etc.
If you can get a hella pump. I replaced mine 2yrs ago with a hella (which I think is oem). I haven't heard of your two options but defintley don't get a first line - they are sh@t.
Post #408273 8th Oct 2016 11:35am
Thanks for the reply, will the wiggle also be causing the leak? (i.e. the wear on the bearing is allowing coolant to pass?)
Had a feel around and behind water pump pulley and it is all wet so guessing new pump needed
Leak only seems to occur while engine running / system under pressure & hot.
This is quite a useful reference: http://www.aa1car.com/library/water_pump.htm .
Post #408274 8th Oct 2016 11:39am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I would go for a MEYLE German one over the Europarts offering, also cheaper on ebay..http://www.ebay.co.uk/itm/BMW-X5-E53-3-0D-...SwFqJWlk28 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #408293 8th Oct 2016 1:14pm
Good find wayne Thumbs Up
For convenience, bit the bullet and got pump, stat, & both drive belts for just over a ton.
Now to dismantle and fit Very Happy .
Post #408319 8th Oct 2016 3:56pm
All sorted, everything came apart nicely, everything went back together nicely. New pump, new 'stat, new drive belts. No leaks Thumbs Up Enjoyed working in reverse/mirror image, when using a mirror to locate bolts in the places you just can't see Laughing
I am sticking with the water pump being the culprit, the shaft was very wobbly compared to the new one.
For reference, the thermostat requires an inverse Torx socket "E8" on my set (probably the reverse of a T30), and the water pump requires a Torx "T30". The two bolts holding the EGR exhaust pipe require a Torx "T45"
Use a 16mm spanner to release the tension on the Air Con belt, use a 24mm spanner to do the same for the main drive belt
I gave a light greasing to the insides of the upper parts of any coolant pipe fixings (the hard plastic parts), just to help with fitting/removing
I fitted the bottom hose to the thermostat before fitting the thermostat, to ensure a good tight fit. They were a swine to get apart on removal.
I have decided for the time being not to refit the fan shroud (given I don't have the fan fitted), this meant having to cable tie the hose running to the transmission oil cooler to the bottom of the radiator, and also to cable tie the two electrical connectors that slot into the RHS of the shroud onto an air con pipe. Will see how this goes.
"Mumbling" Joe Ninety provided the narration on the video:
Post #408480 9th Oct 2016 4:07pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Super and informative video there. Bow down
glad to hear it solved your problem.
Well done and thanks for the info.
greg Thumbs Up
Post #408584 10th Oct 2016 4:36am
wayneg
Excellent video, thanks for taking the time to document it. Did you put all the EGR cooler stuff back or blank it?? 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #408600 10th Oct 2016 6:54am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
When shall I bring mine round for some Joe treatment?! It needs it!!
Post #409321 14th Oct 2016 5:32pm
@gregdav
thanks Smile
@ wayne
It all went back on Wink
@ stacker
anytime if you need the help Wink .
Post #409346 14th Oct 2016 9:31pm
Stacker
I need lots of help!
Doing the turbo hose, front height sensor and front drivers side shock, and a suspension arm this week coming! About time too Sad
Post #409353 14th Oct 2016 10:32pm
mariner30
United Kingdom 2003 Range Rover SE Td6 Rimini Red
Water pump gasket 2003 TD6
I had a sudden leak, having had a very slow loss of coolant. I couldn't see any pipes leaking but the leak appeared to be in the region of the pump, I've just taken the water pump off and discovered it has no gasket. There is no play in the pump. Should there be a gasket if it has been changed since new?
For info in order to try and identify where the leak might come from I topped the expansion tank with water and it just fell out of wherever it is leaking! The pump could be defective but it doesn't look like it. Having taken it all apart I would rather get it right first time when I reassemble it all. I have a new LR thermostat coming as the car had been running cold after I had removed the EGR system. It had a Eurocarparts one about 3 months ago.
Any way should the pump have a gasket?
Post #422102 10th Jan 2017 6:39pm
Yes, it should have a gasket Smile
Check closely, as if original water pump the edges of parts of the gasket are tucked under the surrounding casings. It is also difficult to see properly in that area Shocked
Any wobble on your pump shaft ?
Good time to change the thermostat while you have all this apart Thumbs Up .
Post #422142 10th Jan 2017 10:21pm
mariner30
Thanks Joe90. I took another look after your post and, sure enough, there was the gasket, undamaged and showing no sign of leakage. Sooo next thing is to fit the new thermostat and put the pump back (it must have been changed as it has a metal impeller), connect up all the pipework and pour in some water to see whether it falls out. If it does I'll have to start the search again - if not I'll flash her up and see what happens. Thermostat due in Dumfries tomorrow morning so, weather permitting, I should be able to get this done tomorrow afternoon. Thanks again Joe90 - I should have looked more closely the first time!
And the pump has no play.
Post #422216 11th Jan 2017 4:59pm
was tempted to put an ooer! after this Wink
Glad you found the gasket, hope you find the problem Thumbs Up .
Post #422244 11th Jan 2017 7:43pm
