Home > Maintenance & Mods (L322) > Cooling system 2002 4.4 v8
timffrr
I've got to drain the cooling system to do the thermo stat mod on the range. Is there anything else worth doing while I've got the system drain, problem hoses etc...
Cheers all
Post #421791 8th Jan 2017 7:42pm
espaceboy
I would change to alternator seal
Post #421814 8th Jan 2017 10:09pm
espaceboy
and of course the top and bottom hoses with OEM
Post #421818 8th Jan 2017 10:14pm
Rewmer
radiator and trans cooler. No7 - 2003 V8 Vogue
Post #422079 10th Jan 2017 5:49pm
holidaychicken
Raise the front to bleed and fill coolant to almost top of expansion tank and squeeze bottom and top hoses to burp out air and keep doing with heater on and engine running to avoid chopping your fingers off. The meeknet site has a good bleeding how to
My top rad hose recently blew apart at the steel band that coonects to near the water pump
Post #422112 10th Jan 2017 8:17pm
