Home > In Car Electronics (L322) > 2010-2012 iPod lead ?
Baltic Blue
Please can someone post a picture of the lead that plugs in the glovebox socket.
Mine didn't come with a lead?
Would it charge my iPad mini ? When I use it to connect my new iid tool, or can I just use the USB socket?
Cheers
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #421919 9th Jan 2017 4:11pm
heres one i sold a while back Mike,
http://www.fullfatrr.com/forum/topic38011.html
Post #421924 9th Jan 2017 4:25pm
Baltic Blue
Thanks Stan,
Both my iPad and iPhone have got the newer small type connector.
I will try the USB lead. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #421928 9th Jan 2017 4:34pm
its been mentioned before re an adapter that will allow use of the standard LR ipod lead Mike...
Post #421929 9th Jan 2017 4:40pm
As Stan said but if you only want to charge it then the USB will do the job fine. I use other USB to charge my phone and have a tune2air connected to the iPod connector. So in answer to your question if you just want to charge the USB using the standard apple lead supplied with your iPad will do the job Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #421941 9th Jan 2017 6:05pm
Baltic Blue
Thanks for confirming NMJ.
I just need it to keep it charged, so USB Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #421944 9th Jan 2017 6:17pm
