Home > Technical (L322) > Help needed
tony1kenobee
England 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Help needed
Morning guys , my 2003 l322 has lost all power to the passenger door,.
No window,mirror,or central locking.
Things I have done .
Reset battery.
Read and cleared code with all comms
Taken door card off ,no visible damage to wires.
Checked every fuse related to the door etc
Checked the battery voltage.
I really am flummoxed by this .
Does anyone know where or what I should do next,or what I can check.
I've tried wiki
Any help would be greatly appreciated
Regards in advance Tony
Post #421735 8th Jan 2017 12:47pm
Have you checked there is power to the door control module, they do fail... Pete
Post #421745 8th Jan 2017 1:37pm
tony1kenobee
Thanks for replying. I'm not how to do that, check the power .Is that the box behind the door card with the switches for the window. Cheers Tony
Post #421755 8th Jan 2017 3:35pm
Yes, you need to study the wiring diagram and check there is voltage to the unit, if not it maybe faulty. It could also be a fault in the BECM but I don't think you would have everything out...
Diagnostics will tell you more and stop you wasting money just changing parts... Thumbs Up Pete
Post #421756 8th Jan 2017 3:51pm
espaceboy
have you had the drivers door card off lately?
may be worth pushing all holding all of the connections there as they are linked
Post #421759 8th Jan 2017 4:15pm
tony1kenobee
Had the door card off .unplugged and replugged all connections.ran diagnostic all comms again .but again nothing. I'm well baffled .
Post #421996 9th Jan 2017 10:39pm
