Home > Maintenance & Mods (L322) > Filler cap retainer strap replacement |
trickymickey Member Since: 28 Mar 2014 Location: Worksop Posts: 46 |
I did mine this afternoon and used 17amp wire , perfect for the job ! ......and black. |
3rd May 2015 9:50pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I bought some rubber o ring material off eBay , if you slide one end into the notched cut out it holds really well and the end that fits into the cap I heated up with a lighter and pushed it into the cap so it splays out inside and then can't come back out. I can look up what I used |
8th Jan 2017 3:01am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Yes please. Was it a big oring that you cut? ______________________________
8th Jan 2017 3:12am |
I bought a 1 metre length of 5 mm, it is material that is designed for making your own O ring and gluing together
8th Jan 2017 9:58am |
Thanks, yes please. ______________________________
8th Jan 2017 9:13pm |
Pic attached below, it is a bit dark and rainy here.
9th Jan 2017 10:08pm |
Thanks. ______________________________
9th Jan 2017 10:48pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Hello,
10th Jan 2017 2:54pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3836 |
In my mod the drive belt eventually perishes with the petrol fumes, might be OK on a diesel - don't know. So I now use a part of a lanyard that half the working population seem to have round their neck with passes or some such dangling on the end. Its cloth - so far so good.
10th Jan 2017 3:12pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
Stupid question of the day: Does the old retainer just pull out of the top of the filler cap? I don't want to leave anything stuck inside. 2012 5.0L S/C
10th Jan 2017 4:20pm |
The plastic cover of the fuel cap pops off. Under the top is a spring. Under that is the strap. I pushed it out using a screw driver. ______________________________
11th Jan 2017 11:47am |
Thanks 2012 5.0L S/C
11th Jan 2017 4:13pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
CHECK THIS OUT!!
10th May 2019 2:09pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 |
I did a few months ago when I fixed mine. Then I saw the price and fixed it with a short piece of heatshrink tubing instead. £15? They're having a laugh! 2016 Skoda Octavia VRS Estate
10th May 2019 8:08pm |
