Home > Maintenance & Mods (L322) > Heated wind screen 2010
Lup
Sweden 2010 Range Rover Supercharged 5.0 SC V8 Nara Bronze
I have a 2010 and it seems the heated wind screen isn't working.
My first thing to check would be the fuse/fuses but I can't find any fuse with the description "heated wind screen".
Anyone know what fuse I should check? **********
Fullfatrr 5.0 S/C 2010
Defender TD5 2002
Post #421501 6th Jan 2017 9:01pm
Baltic Blue
Hope you can read this wiring diagram.
Someone may be able to post a better picture. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #421503 6th Jan 2017 9:15pm
i think its in the front engine compartment fuse box, F11 and F14 ??
Post #421504 6th Jan 2017 9:25pm
Baltic Blue
If it is not the fuses, I would go for relay 7. or relay 3. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #421506 6th Jan 2017 9:29pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
That is correct Stan - Engine Compartment Fuses 11 (left side) & 14 (right side)
Also a 250A fusible link in the battery area, but presumably many other things wouldn't work if that had blown.
If not fuses, consider the relays - again Engine Compartment Fuse Box - R3 (left side) and R7 (right side).
Since left and right side are largely independent circuits, if both not working suggests something else. The relays are triggered by orange/grey wire from "Central Electronics Module CEM" supplying earth on pin C0584-29. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #421508 6th Jan 2017 9:40pm
Does it get warm in the wiper area ?
When they replaced my L405 windscreen, the heater didn't work - turned out there are 2 connectors - one does the wiper area and the other the whole screen - and for some reason, they are the same.
The guy who fitted the windscreen connected the wrong ones, so the wiper area cleared, but not the rest of the screen.
The guy who came to fix the issue could feel the wiper area getting warm, so realised the issue. He removed the covers on the pillars using a torx driver - there's a single screw under the airbag badge on the pillar cover - the connectors are down at the bottom.
Post #421511 6th Jan 2017 9:47pm
