Home > Technical (L322) > 3.6 tdv8 FBH shuts down prematurely |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi Henrik, have a read in the wiki on here, under info. It appears the fbh will not work below a certain voltage.
6th Jan 2017 7:25am |
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 |
My FBH works well when the engine is running but shuts down within a few minutes when engine is off. I haven't done any more checks but I'm pretty sure the water pump in the FBH is seized. When the engine is running, there are sufficient circulation thru the FBH but when the circulation stops, the FBH overheats and then shuts down. "Plentraktoren/Garden tractor": 2008 L322 TDV8
6th Jan 2017 7:37am |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Search for Rover 75 - there are links on here to a great diagnostic thread by a FBH expert
6th Jan 2017 4:33pm |
This one is a good start, there is also lots of other info
6th Jan 2017 10:25pm |
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 63 |
Thanks for the input.
16th Jan 2017 6:42pm |
