Home > In Car Electronics (L322) > radio interference
razzer
England 2003 Range Rover HSE Td6 Zambezi Silver
radio interference
hi all, can anyone shed any light on my radio interference, it happens when i switch the rear heated window on and i also loose the radio channels when it is extremely cold first thing in the morning. all i get is static Whistle
Post #421250 5th Jan 2017 1:45pm
proser
Has the rear windows been tinted (after market ) ??
If it has then that can be the cause of the problem. some tint film has metal in and when the heated rear window is switched on causes a block on the radio reception as it uses the same element for both operations. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #421255 5th Jan 2017 2:00pm
razzer
no its not tinted, thanks for the reply
Post #421259 5th Jan 2017 2:29pm
proser
It could be an issue with the antenna module that plugs into the rear screen, where it is acting as an earth for the HRW and therefore blocking the radio reception. Regards
Mark
2012 Westminster
Post #421264 5th Jan 2017 2:58pm
