![]() | Home > Maintenance & Mods (L322) > Parking sensors no longer working...constant beep then flash |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Do you have front and rear fitted to your vehicle?
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
What he said ^ but I would describe the noise they make as a clicking rather than buzz |
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 ![]() ![]() ![]() |
I have a similar problem on my 2005 Supercharged Range Rover. It is fitted with the rear view camera which seems to have some dirt on the lens as the image is a bit blurred. When I put it into reverse, then is a beep and then nothing but the switch is flashing. When I drive into an obstruction forward, I press the parking but and again there is a beep and then a sustained beep.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
on my 03 , all the sensors are active when reverse is selected OR the switch is used , I had a wiring fault to one front corner sensor , repaired the wire , all good |
Dreckly Member Since: 16 Apr 2015 Location: Truro, Cornwall Posts: 47 ![]() ![]() ![]() |
With my 06 S/C I repaired the rear loom. It had worn through the insulation in various places where it passed over the "bumper iron". After the repair I applied extra insulation where I thought it might rub through again & gave the connections a liberal coating of petroluem jelly.
All my rear ones are clicking when in reverse. Do I need to move the gear stick to the Drive position to hear if the front ones are clicking once the parking aid button has been pressed? Or should the front sensors click when the car has been put into reverse?
Hi Steve,
Hi Ken,
gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162 ![]() ![]() |
Put your finger on each one gently, you can feel them pulse, if one is not that is your problem, often the contacts just need cleaning up. Porsche 911 (996)
