![]() | Home > Technical (L322) > Help required Coolant Issues |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
I've got g48 in mine. Is there a possibility mixing the two has bunged up the car? |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
The antifreeze should be blue/ green and shouldn't mix with the red type.
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
common faults with coolant/ if you have a leak somewhere it can be difficult to find due to the heat generated by engine ..pressure is usually caused by airlock ie not bled properly. header tanks can be a problem. change thermostat to 80 deg one which will lower pressure and heat . get a pressure test done on system and make sure she is bled right which can take time and patience/ you need a 200 cap as pressure generated turns water to steam and will leak out past cap/you will hardly see where the leak is coming from as any water leak is evaporated instantly leaving a nice whie mark on offending area water pump rear knuckle joint rad header tank also if top hose plastic is brown in colour change it asap as it may destroy itself best modification is 80 deg thermostat good luck |
and oat orange is correct antifreeze dont mix with any other colour but get system sorted first as it will cost you to keep replacing it |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8394 ![]() ![]() ![]() |
First off go and get a genuine tank, Dan at Duckworths, site sponsor will sort you out with a good price, he can also tell from your vin which cap you need.
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 ![]() ![]() ![]() |
Thanks for the replies guys.
Unlikely a stuck stat would do that, more likely a blocked radiator or could be an airlock, I'd try for the airlock first, remove the rad cap and let it tick over for ages, see if some air gets blown out... |
The top hose is not normally a jubilee clip, it is supposed to be a bonded seal with a steel band around it , there is nothing for the jubilee clip to grip to, I have just changed my hose.
small top hose to expansion tank has a jubilee clip better replace hase as they get knackered and break off def bleed air do it a few times and leave overnight then check when cold in the morning will prob need some water |
OK had her all apart today.
Well all back together now.
