![]() | Home > Maintenance & Mods (L322) > Help Needed - Fast Flashers - |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3660 ![]() ![]() |
They will do fine if you have real light bulbs in the front indicators... otherwise the circuit is going to be 20 watts light.....
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 163 ![]() ![]() ![]() |
Okay right on, I was wondering, are there any flasher relay modules installed in 2004 BMW Range Rover? Because I can hear the flickering sound when the indicators are on, however that flickering sound usually is sourced from the relays that control indicators on majority of the vehicles. I looked around and a lot of people said that our RR's have their indicators controlled by the LCM, if that is the case, where is the indicator sound inside the cabin being sourced from? Zambezi Silver Range Rover (2010 Autobiography Facelift)
There is a speaker behind the dash cluster that makes the sound, and it also does the front PDC bong as well, Oh and the Death Bong when the Screen of Doom fires up and says this is going to hurt |
