Home > In Car Electronics (L322) > Number plate bulb size?
HGv driver
Wales
Just got home opened boot noticed I got a number plate bulb out,I take it it's a festooned bulb but it was too cold and dark to remove it just looked to swap to led's anybody tell me what size is the bulb thank you as you were happy new year
Post #419798 27th Dec 2016 10:06pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
Yes it's a festoon bulb. 5W size 11mm x 35mm.
There is a useful lookup tool on the Osram website.
https://am-application.osram.info/en
Steve Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #419799 27th Dec 2016 10:36pm
HGv driver
Wales
Thank you for that
Post #419801 27th Dec 2016 10:49pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
These were recommended on here recently as an upgrade.
http://www.ebay.co.uk/itm/301877126069?_tr...EBIDX%3AIT 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #419817 28th Dec 2016 2:12am
alistairh
Says they are error free but also says they can cause issues in sensitive cars? Has anybody tried them yet..I've changed all interior to leds then sidelights. I'm wanting to do something with the reverse and number plate ones next Thumbs Up
Post #420389 31st Dec 2016 4:31pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I thought those were the reversing light bulbs?
I fitted these number plate lights, bit of a tight fit but no issues.
http://www.ebay.ie/itm/141857574520?_trksi...EBIDX%3AIT
Post #420484 31st Dec 2016 8:25pm
alistairh
Perfect.. how many leds where on the ones you purchased buddy? There's a couple of choices Thumbs Up
Post #420487 31st Dec 2016 9:05pm
hamlet
Off the top of my head I think I put 2 in the footwells, 2 in the numberplate lights and one in the rear right loading loading space (boot).
I put these every where else.
http://www.ebay.ie/itm/201525998008?_trksi...EBIDX%3AIT
Just the puddle lights in the door mirrors to do which seem to cause a bit of a problem.
Post #420491 31st Dec 2016 9:23pm
hamlet
Sorry, I read that wrong, 6 led's on each I think, I'll check and let you know if they were different but I'm 99.9% sure they were 6.
Post #420492 31st Dec 2016 9:25pm
alistairh
Post #420496 31st Dec 2016 9:50pm
steveball
There are quite a lot of options for bulbs. I have recently replaced the following.
I've included pictures because eventually the eBay links will expire and there is nothing more annoying that seeing a useful post but not being able to see what's being referred to!
Number plate bulbs. These are originally 5w festoon bulbs, 35mm long
I used the following. A good upgrade and fit easily. No warning messages (but I checked and no warnings when no bulbs at all, so clearly not being monitored).
http://www.ebay.co.uk/itm/162192255771?_tr...EBIDX%3AIT
Reversing light bulbs. These are originally 434 / BAx9S 5w filament bulbs with offset pins.
I used the following. They are quite a bit brighter than the originals (though that's not hard). Again, no warning messages.
Others have had good success with SMD panels, but this requires that the light fitting is split open. Apparently not hard and gives a very good light.
The ones I've used just about fit within the fitting without having to split it open. They could do with being 1mm shorter - as they are you can't turn the bulb holder to lock it into place, but once the light fitting is back on the car, it's held in place nicely anyway.
http://www.ebay.co.uk/itm/371681246684?_tr...EBIDX%3AIT
Hope that helps. Current: 2010 Range Rover L322
Post #420500 31st Dec 2016 10:07pm
alistairh
That's great! Thanks for the write up.. ordered Thumbs Up
Post #420502 31st Dec 2016 10:23pm
miggit
My foot well lamps are T5's (capless) not festoon, the only festoon bulbs that I have come across are the number plate lamps Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #420512 31st Dec 2016 11:55pm
V8Noise
You are correct Hamlet. My apologies for leading the OP astray. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #420518 1st Jan 2017 7:49am
V8Noise
Incorrect quote Confused Embarassed
I blame it on copious quantities of alcohol last evening. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #420519 1st Jan 2017 7:50am
