![]() | Home > Technical (L322) > Permanent live in boot? |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1455 ![]() ![]() |
Need a permanent live in boot, prefereably left hand cubby hole but doesn't seem to be anything obvious there. The right hand cubby hole has the fuse box but not sure which ones would be permanently live. Manual not that helpful. 2021 D350 Fifty Edition - Carpathian Grey
Yes Alistair that's true but I was hoping to find a fuse I could use. 2021 D350 Fifty Edition - Carpathian Grey
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35525 ![]() ![]() |
standing at the back and looking into the FF, theres a fuse box on the right cubby Rob......use a multimeter to see which is a permanent live and use a piggy back fuse and if you need that on the left then run a wire from one side to the other.... ... - .- -.
Thanks Stan. Have a multimeter so will check the fuses out. Is it a problem if I say use the fuse that's for something else? Not an auto electrician so need some guidance |
it will be ok as long as the amps of the 'new' item doesnt go over the fuse amperage.. ... - .- -.
Should be fine as I think I need less than an amp. Cheers.
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
Strictly, it will be ok if the combined maximum current demand of the exiting devices on the circuit, plus that of the new device don't exceed the fuse rating. Trouble is, you probably don't know what current the existing devices draw, so it's guesswork at best. If you're dealing with a low current new device, it'll probably be fine. If it's a higher draw device, I'd probably go a different way.
Cheers Steve. F8 (15a) and F9 (30a) both seem to have trailer symbols but I don't have either a towbar or electrics and they seem to be permanent live so should be usable. Failing that I will connect to the big fat permanent live cable and use an inline fuse.
Hi Rob - It looks like you might be in luck. I've had a quick look at mine (2010MY, so guessing its the same or similar to yours) and I think there is a perm +12v which is fairly accessible.
Thanks Steve, will investigate that one.
