Home > Maintenance & Mods (L322) > headlight power washers |
Pictures required please (Of the car) |
12th Dec 2010 8:48am |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
Hi yes you will have a problem as the headlight washer is fed from the headlight unit the best way to do this is join the wire from the screen wash to headlight wash then when screen is washed so to will headlights |
12th Dec 2010 12:04pm |
But then you will empty the tank rather quickly as the ECU will ignore the built in logic for when to run the washers... Could the BCM have detected that the motors arent present? So its dissabled the washers? For example assuming that its SE spec without wash/wipe? Dan |
12th Dec 2010 12:12pm |
Hi if you look at the left hand plug that fed the old headlight you will see it has 4 wires the little yellow wire is the feed to the pump it is controled from the bcu but it was via the headlight so to control it again you have to do wiring mods im unsure what actually goes on within the headlight but will look into it, if you look at wiring diagram the pump is just connected to headlight |
12th Dec 2010 12:38pm |
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 |
thanks for any help guys. probably a stupid question but how do i attach photos? |
12th Dec 2010 11:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 |
look here aaron.. http://www.fullfatrr.com/forum/topic1023.html ... - .- -. Y. O. L. O. . |
13th Dec 2010 8:29am |
