Home > Technical (L322) > Battery charging rate???
stefan063
Yugoslavia 2012 Range Rover Autobiography Black TDV8 Barolo Black
I have noticed something regarding my battery management system in my RR.
When I start my car (from yesterday) I have noticed lower charge rate (looking at Navi service menu)
First it charges battery at 11.6 - 11.7 Volt then it goes to 12.4 -12.5 Volt and after 10km or 10 min of driving it goes to 14.2-14.3 Volts. Is this normal operation? I do have battery management system on my RR. And I saw on negative terminal sticker that says where it was re-calibrated. Basically on the day I bought new battery.
Is this normal? Shouldn't it bump up Voltage to 14.4- 14.6 Volt on start up like any other car?
Post #419536 25th Dec 2016 12:55pm
It doesn't charge the battery straight away to relieve pressure on the system, they all have this smart charge system, it only takes a matter of seconds to replenish the battery after a start, the amount of energy used is very small, the starter only runs for about a second...
The charge rate will vary depending on how many electrical items you have on at any time...
So nothing to worry about... Thumbs Up Thumbs Up Pete
Post #419561 25th Dec 2016 8:01pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Stefan
My system fairly quickly goes up to 14.7 volts after starting. By fairly quickly I mean 2 or 3 seconds.
Which is where it mostly stays.
At 11.6v the battery is not being charged...
Post #419586 25th Dec 2016 11:16pm
