Home > Technical (L322) > TDV8 turning over but won't start |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 |
Hey, Sorry to hear of your troubles! My TDv8 is doing the exact same thing, bar the low fuel pressure warning.
19th Dec 2016 4:20pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 803 |
I found when I put in the cheapest diesel I could find, it was a struggle sometimes to start.
19th Dec 2016 4:52pm |
StefanW Member Since: 10 Dec 2016 Location: Star Court Posts: 4 |
Update: Drove down to the workshop again today, cleared the codes yet again, re-bled the low pressure side again, verified that neither the fuel filter block nor the fuel cooler were blocked.
23rd Dec 2016 6:20pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2486 |
I would not assume that the HPFP has failed as I expect its pressure to be ecu controlled. |
23rd Dec 2016 11:00pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8239 |
Although with a low pressure fault and no pressure at the rail I think I'd be leaning towards a new pump, they are a common failure point... Pete
24th Dec 2016 1:41pm |
24th Dec 2016 7:26pm |
Turned out to be the HPF pump that had decided to call it quits...but not in the normal way...the pulley had come loose somehow, but I replaced the pump with the new as I had already sourced it. |
20th Jan 2017 10:51am |
