Home > Technical (L322) > How to Find Top Dead Center TDV8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8284 |
I'm sorry but I have to disagree, if it was running fine then suddenly cut off and wouldn't start them I can't see it being a head gasket, it wouldn't lose enough compression over 8 cylinders to cut out in such a short period of time, if one gasket failed, and it's unlikely to have a dramatic 4 cylinder failure, then it should still run like a pig on the other side, if it started to run bad then cut out it sounds more like a fuel issue, especially as it now starts with a bit of easy start.
24th Dec 2016 12:08pm |
Matt_980 Member Since: 23 Dec 2016 Location: wiltshire Posts: 1 |
Hi
25th Dec 2016 8:57am |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 |
Hey Everyone.
25th Dec 2016 4:49pm |
I went at the RR today. Gave the battery a full charge overnight and connected her back up this afternoon.
27th Dec 2016 5:48pm |
Sorry, don't know enough about the fuel of the devil but I'd swap the injector with another one to see if the problem swaps with it...
27th Dec 2016 7:03pm |
I must try and find out which cylinder the injector corespondent too, as I don't think they match with the same cylinder number? I've got a new error code tonight. P0266 Cylinder 2 Contribution/Balance Fault. Probably related to this. |
27th Dec 2016 7:49pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Whilst the engine is running and you have live values, can you pull the plug off one of the injectors and see what it corresponds to on your diagnosis tool.
27th Dec 2016 9:19pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1775 |
Issue is with Cyl 4, overfuelling, massively
27th Dec 2016 11:51pm |
DO NOT unplug an injector when the engine is running You risk causing irreparable damage to the PCM internals |
27th Dec 2016 11:54pm |
I have a spare injector. I'm going to change back to that one tomorrow on Cylinder number 4.
28th Dec 2016 12:03am |
When I put revs on the engine all cylinder including number 4 display the same readings. |
28th Dec 2016 12:04am |
As I mentioned earlier.
28th Dec 2016 12:21am |
Ok.
28th Dec 2016 12:32pm |
28th Dec 2016 12:39pm |
