![]() | Home > Maintenance & Mods (L322) > LED main beam headlight bulbs |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
I was wondering whether anyone has any experience with replacing ordinary filament headlight bulbs with an LED equivalent, either in FFRR or anything else I suppose.
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
I've upgraded the high beam bulbs with the 2x55w (110W) ZY P6 10400lm H7 Canbus ones (see http://www.fullfatrr.com/forum/topic39089.html). I'm very happy with these - gives a lot more light than the original halogen high beam bulbs. You should try to get a set where the LEDs are places exactly at the same distance from the base as the filament in the halogen lamp, then you get the most correct light characteristic. |
Thanks, both, for you experiences. That's helpful to know. The bulbs that seem to work well are about 3x the price of the cheaper ones, so will be interested to hear how you get on Scott. Current: 2010 Range Rover L322
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 ![]() ![]() ![]() |
Yep...Watching this closely! Jordan
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
this chap on the RRS forum has done it,
Hmmm..... thanks Stan, some interesting and enthusiastic comments there. Starting to make me think that this is worth pursuing. Current: 2010 Range Rover L322
it all depends how much illumination you need...i've tweaked mine up a bit and although they are still 4300k [to be changed soon to 6000k] they do light up the road pretty well... ... - .- -.
