Home > Off Topic > Router advice please ( The woodwork kind )
Johnte
Can any experienced wood workers offer advice on buying a Router please- The main use will be for fitting kitchen worktops.
I'm not a joiner, but in the past I've always fitted our own kitchens, then called in a pro for the worktops. This time I'd like to have a go at the worktops myself.
I was looking at the Dewalt 625. Would this be a reasonable mid range option ?
Post #418647 19th Dec 2016 2:51pm
If the life expectancy is a single kitchen, then I'd think most would be OK with a decent blade. I've managed ok with a crappy old Black & Decker - you just have to take your time with shallower cuts.
I've just done my first granite worktop Thumbs Up
We had ours fitted professionally many years ago and they have been great - so we bought a 2nd hand set of worktops off eBay for my sons kitchen - had to do some trimming to size and a little polishing but I'm pleased with the results.
Post #418649 19th Dec 2016 3:21pm
Weegie
See my reply on the D2 forum. Wink Thumbs Up John
GAP iiD BT
Post #418654 19th Dec 2016 3:38pm
Johnte
Have done Thumbs Up
Post #418664 19th Dec 2016 4:36pm
miggit
In my experience any router will do the job... however if you want to make life easy then I would suggest that you look for a 1/2" collet version... I have used DeWalt.. fantastic if your fitting worktops for a living.. I have also used a cheap chinese thing, think it was preformance power or something like, bit basic but did the job well..
Soft start is a very good feature on a large router... remember using a Makita in the early 80's and you had to hang on for dear life on startup Shocked
Something like this will do it Thumbs Up
http://www.ebay.co.uk/itm/1500W-1-2-Inch-H...SwYIxX9iAN
You can get cutter sets from toolstation from £15
The biggest advantage with a 1/2" router is it can do a cut in one pass Bow down But I would recommend that you do several so it's not too stressed and the laminate isn't chipped.. and that's assuming that your cutting laminate worktops... if your doing composite worktops (corian etc) you'll need a diamond cutter, and a router around 2000 watts is a real advantage Thumbs Up
Just make sure that they take guide bushes Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #418826 20th Dec 2016 3:00pm
miggit
This is a slightly less agricultural router.. GMC are silverline posh tools.. not that there is anything wrong with silverline.. their backup is good.. The GMC tools are better finished, and that one has a bit more umph!!
http://www.ebay.co.uk/itm/GMC-1800W-Electr...Sw-0xYVB3s
and then you start to get into the heavy weights.....
http://www.ebay.co.uk/itm/1-2-HEAVY-DUTY-P...SwiONYNG7z Yesterday I couldn't spell Engineer... Today I are one!
Post #418830 20th Dec 2016 3:11pm
for doing one kitchen worktop then any old router will do, 1/2" collet and a decent straight blade. Make sure that you get a worktop jig then your life will be a lot easier!
Have a look at rental as well. The rates are not normally bad and the kit will be more heavy duty. There is nothing that can't be fixed with a hammer😜😜
Post #418841 20th Dec 2016 4:29pm
