Home > Technical (L322) > Not an air suspension inactive thread - honest!
No, it's a thread about the dangers of overloading your crane.
Incidentally, while I'm in the technical section, I recently had an air suspension inactive message, which when cleared by the IID tool comes back after driving 100m or so, then the lights go out on the display.
I cleared the message and then raised the car. It went up fine but took ages for the light saying 'raised' to stop blinking. When I lowered it, the car did go down, but the middle light indicating it's at normal height didn't stop blinking.
I'm thinking that there's clearly nothing wrong with the compressor or the airbags as it goes up and down fine, so there must be a problem with a sensor - but which?
All replies from grateful crane operators, or anyone else for that matter, gladly received!
Post #418533 18th Dec 2016 8:00pm
jambo27
Sorry I have no crane operator experience ...
But as luck would have it I had the same fault on my RR. In my case was caused by faulty ride height sensor (easier to spot on mine due to the flashing red lines on the 4x4 info screen). If i remember correctly the sensors work in diagonal pairs and based on the difference in values between the two sensors the system can work out where the axle height is in relation to the other wheels. If a sensor goes wrong the values go outside the acceptable range and the system cries and sulks. I could reset mine and it could be fine for days even weeks until I drove over some terrain that pushed the sensors towards their upper limits ie large kerb, pothole etc and then the fault would occur again. 2008 TDV8
Post #418550 18th Dec 2016 9:17pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Rolling with laughter Rolling with laughter Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #418555 18th Dec 2016 9:34pm
Yep, as said it's a height sensor, live values should show which one, I've had all mine fail in the last year so if I were you I'd change the lot.... and don't buy pattern, they don't have a metal insert for the bolts that hold them on so you are threading into plastic...!!! Thumbs Up Pete
Post #418634 19th Dec 2016 12:35pm
Thanks Heylands and jambo27.
I'll have a look at the live values (didn't know you could), but think I'll take your advice and do them all.
Will do a search on recalibrating....
Post #418671 19th Dec 2016 5:19pm
These are the live values. Front left moved between 22 and 24 that's all, even when braking and turning right so I think that's the dead one.
Anyone know of a guide on recalibration - I've had a search round but can't find one?
Post #419012 21st Dec 2016 1:55pm
any good?
http://www.fullfatrr.com/gallery/albums/us...on_Aid.pdf ... - .- -.
Post #419020 21st Dec 2016 2:14pm
The BTIID has an idiot's wizzard to re calibration, even I managed to do it first time, just need the tool and a tape measure... Thumbs Up Thumbs Up Pete
Post #419030 21st Dec 2016 3:26pm
Thanks guys.
Post #419035 21st Dec 2016 4:21pm
Have you tuned your car accidently Kurt - i mean like a suburb chav ? Laughing All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #419046 21st Dec 2016 5:51pm
This is the slammed look I'm going for.
Post #419060 21st Dec 2016 6:21pm
Shocked Oh my god that is german ! All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #419065 21st Dec 2016 7:05pm
Well you Germans are known for your good taste.
Post #419071 21st Dec 2016 7:22pm
Laughing error not really hahaha All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #419101 21st Dec 2016 9:50pm
holidaychicken
Re: Not an air suspension inactive thread - honest!
It is somewhat cruel but unfortunately quite a common problem..
Post #419117 22nd Dec 2016 5:37am
