[For Sale] 2004 Defender 110 TD5 double cab £12k | |
FOR SALE-
My 2004 Defender 110 double cab
First registered 9/3/04
currently done 131500 miles
Brand new Factory 20p engine fitted at 69000 miles as well as turbo/clutch/flywheel etc (over £5000 receipt)
solid chassis
i have owned the car since 7/8/15 and i have done the following-
Fitted a set of genuine Matt Lee Mach 5 rolled rim wheels with 33/12.5/15 bf goodrich all terrain tyres
Replaced the tub rear corners and cappings
replaced both front doors with Puma steel rolled top doors
replaced complete wiper linkage and motor
replaced all brake pipes
replaced rear axle a-frame ball joint
replaced brake servo/pedal assy
fitted modified clutch return spring kit
Fitted flip out DVD/CD player
Fitted full set of modified range rover classic grey leather seats (electric front)
BAS remap
Allisport intercooler
silicone boost hoses
modified exhaust manifold (refaced and webs removed and stronger studs)
Decat pipe/straight through centre pipe
Terrafirma big bore shocks
new rear half shafts /drive flanges
Stainless wheel nuts/locking nuts
New genuine springs (standard height)
Galvanised rock sliders
LED Lynx eye headlights
Full LED lights side/brake/indicator/numberplate light
Roof bar with 4 LED spot lights (switched)
ARB style bumper with 2 LED spotlights (switched)
genuine safari snorkel
Britpart cubby box
height adjustable towbar
Series 3 headlights surrounds
Personal fittipaldi leather rimmed steering wheel
Raptor sprayed rear tub
There is probably much more that i will add as i remember
Build thread here-http://www.defender2.net/forum/topic39170.html
The bodywork has been tidied up and straightened to a reasonable state but not perfect as you would expect from a 12 year old workhorse. I have recently hand painted (gloss roller) it in satin pale green (jotun conceal marine paint) and it looks fine from a couple of feet away but as its hand painted it is not perfect but easily touched up (comes with half a 5L tin of touch up).
It also has unique security features which i won't go into on here for obvious reasons
£12000 o.n.owhich i think is a realistic price for this spec of car
Will get some better, more up to date photos this weekend
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
