Home > Technical (L322) > Jobs worth doing alongside EGR's - tdv8?
jonnyboy54321
As per title, am doing the EGR's on our '07 tdv8.
Are there any other preventative maintenance jobs that could/should be done at the same time while she's in bits?
Thanks
John 2007 Vogue TDV8 with 255/55/20's fitted
Post #418040 15th Dec 2016 5:38pm
Bantam
2007 Range Rover Vogue SE TDV8 Java Black
I had mine done last year at an independent - he told me he always tests the pre-heaters as they go faulty quite often. I just told him to change the lot - last thing I need is cold starting problems. I have no idea how to test them, but it wasn't overly expensive to change them anyway.
Post #418093 16th Dec 2016 12:37am
Robgosty
While doing em have a close look at thermostat housing, when i had turbos egr valves etc etc found a weep from housing so changed it just to be on safe side Cool
Post #418187 16th Dec 2016 5:54pm
jonnyboy54321
Decided as the thermo housing with the two elbow hoses is £100 that I'd wait till it's stripped for egrs.
Didn't want to be stuck with bits I don't need.
You cant see in my crappy pic but it also has a weep on the rhs of the housing.
Picking them up tomorrow Censored 2007 Vogue TDV8 with 255/55/20's fitted
Post #418864 20th Dec 2016 5:47pm
