![]() | Home > Technical (L405) > L405 woes |
So, bought my 2014 VSE a few months back and it's back at the dealer again. 4th time for the same damn fault which has never been rectified despite a huge amount of replacement parts.
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 ![]() ![]() |
There have been problems with failed anti-roll bar bushes I am told. Mine are being replaced after 14k miles. Replicated knock with Tech. guy onboard. Will report back when job completed.
I had presumed that the ARC system (a snip at �1800) included the anti roll bar and various other hydraulic bits. If replacing the ARB I had again thought it would come with new bushes. 2 large assumptions where LR are concerned I guess.
My first 405 was Jan 2014. It is possible that the valve block for the ARC was not replaced with the updated twin dampers version.
Well that was a good call Doodle. Valve block replaced, peace and quiet resumed. |
Good news that knocking fixed and 4 wheel alinement worked. Now you can fully appreciate your 405 |
Wo ping Member Since: 17 Aug 2014 Location: Scotland Posts: 7 ![]() |
my 405 had the ARB work done months and its still clunking and thunking. really annoying. its been in 4 times in a year but i still love the car.
Has yours had the ARC valve block replaced? That's what cured mine. |
hi, yes it has but its not fixed it ! |
Then ask them to check the ARB bushes. The 'knocking' as they gradually fail, is very similar and as loud as the valve block issue.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 755 ![]() ![]() |
Have you spoken directly with the warranty provider to challenge to decision to not cover it?
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
If it is of any conciliation my last 3 L494’s, which were all brand new, all pulled to the left from the first day of ownership. Each time I returned them and asked for them to be 4 wheel aligned on a Hunter system or similar free of charge. After alignment they all drove as they should have.
Johnboy
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
I'm awakening an old thread here.
