![]() | Home > Technical (L322) > Blue/Grey Vaccum hose to EGR access |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Fill in your car profile, so as people know which model / year you are asking about.
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
sorry it's L322 td6 2003 |
If I recall, the vacuum pipe to the egr comes from the main vacuum unit on the left hand side as you look at it from the front. Then weaves its way to the front, over the engine and down through the intake manifold to the egr.
Just another thought, you may be getting that fault code if you already have an egr delete, as I have a common fault on the egr, and mines deleted.
Hi Greg, thanks for the response, Yes I have the EGR removed and a blanking kit fitted. the fault appeared after I did the EGR blank. Fuel consumption is slowly increasing since then.
Hi , yes you are looking for a black plastic type cylinder shape item just behind the big black box that houses all the electric ecu's etc.
Thanks Greg, that gives me something to go on and check.
Update: The blue/grey vacuum hose from the EGR has and holds vacuum when the engine is running, so that eliminate that hose as a leak.
