Home > LPG > Fuel Pump problem caused by LPG? |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Pumps do wear out. Your car will run on petrol until the water is warm enough to vaporise the LPG. On mine it takes a couple of miles at this time of year. I can't see how running a tank of petrol through will make much difference, but I guess you can try it. |
8th Dec 2016 12:56pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
kirton
8th Dec 2016 2:34pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 |
It won't be the petrol fuel pump that's sticking. The LPG may need recalibrating and it will be the sensors that are throwing the management light and thus the code when the LPG is being used.
8th Dec 2016 3:03pm |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
FWIW my fuel pump packed up at about 120k miles so they do fail. No warning, no EML, the car just wouldn't start one day. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie |
8th Dec 2016 6:31pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
biggest culprit of fuel pump failure on LPG converted car's in general is lack of petrol in the tank, best thing to do is keep it over 1/4 at all times that way you should be safe |
10th Dec 2016 9:32pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8340 |
Don't know what sort of suggestion that was but may I suggest you find a new mechanic... If it's running lean on LPG then there is one thing it CAN'T be and that is the PETROL fuel pump...!!!! And as Dingg1 said, the pump runs all the time to cool the injectors when running on LPG, the petrol side gets enough use for the few minutes each morning before the LPG cuts in.. Lots of reasons why it will run lean on LPG and put the MIL light on, from holed diaphragm in the vaporiser to a blocked filter etc Time to get the LPG system serviced and checked.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
11th Dec 2016 2:22pm |
kirton Member Since: 24 Jan 2014 Location: Crediton Posts: 50 |
Turned out to be a failing oxygen sensor. |
23rd Jan 2017 2:32pm |
Replaced with a new Bosch sensor. Failed within 24 hours.
8th Feb 2017 5:45pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3186 |
@kirton, how did you find out it was an oxygen sensor? What was the fault code? Cost to replace?
27th Feb 2017 1:12pm |
Dolphinboy,
27th Feb 2017 4:32pm |
Hi Dolphinboy, I found the X5 bosch pump that looked like the one in the link http://www.ebay.co.uk/itm/For-BMW-X5-Range...1942820613 It was about £100 if memory serves. I fitted it a few years back, it is still going strong now. There is a how to video on youtube, good luck 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie |
27th Feb 2017 7:01pm |
Jmckenzie295 Member Since: 18 Apr 2018 Location: Glasgow Posts: 17 |
My fuel pump just packed in last month and changed it with helpful a similar video as above. I have been told to keep it over 1/4 tank.
18th Apr 2018 10:25pm |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
Very good info did mine a couple of months ago and all was well pump nice and quiet . However after a week or two pump has became noisey . Pretty irritating hum all the time . Pump was x5 one £39 no issues with fuel pressure starting etc .Bought from eBay so contacted seller who has very kindly sent a replacement .not had time to change yet but am carrying spare pump just in case .
18th Apr 2018 11:30pm |
