![]() | Home > Maintenance & Mods (L322) > Which is the best Headlamp bulb? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
I've done the search and I can't really find the answer to my question. I guess the two best bulbs are Philip Extreme Vision and/or Osram Nightbreaker so any thoughts on either or both would be appreciated, then where to buy as they are pretty expensive.
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Used nightbreakers a few times seem an improvement over OEM. There are some new bulbs out one of the mag's did a test on a few weeks ago but I think the nightbreakers came back best value for money. Some reports of them not lasting as long but mine always lasted while I had the vehicle.
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
Osram nightbreaker unlimited are awesome bulbs and legal too. I fitted them to a disco 2 and they are as good if not better than the xenons in the FF. What are you fitting them in? 2004 RR 4.4 V8 Autobiography |
I'm actually replacing the HID bulbs in my FF so not H7 but D3S Geoff |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
I changed mine a bit back, have a read here,
So "Lad" from reading the thread it looks like you got plenty of benefit. I seem to have similar problems - lights starts off bright and immediately gets dimmer. The beam pattern looks OK, not too worried about the H7s they seem to work fine.
Yes, mine started bright but went dim. The new ones were a lot brighter. Could see further down the road. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
I think 2010MY onwards have both.
