Home > In Car Electronics (L322) > Latest project complete - upgrade analogue tv to DTV
Fatzo
France 2011 Range Rover Vogue TDV8 Ipanema Sand
would this work for the french TNT?
Post #416799 5th Dec 2016 9:47pm
Weegie
It depends on whether it will decode HD (DVB-T, MPEG4). I haven't looked closely at what has been done but, if it is a conversion which only accepts SD (MPEG2) then it won't.
As you know all French TNT went to HD in April this year.
I have a digital unit which works in UK because the transmissions are still SD as well as HD but doesn't work in France.
I did post a thread some time ago trying to establish if there was a decoder that would work but got no joy. I wondered if the later models of the RR had HD which might be compatible (at a price!) but got no further.
It may be that the boxes could be converted to the HD standard but I haven't looked at that. John
GAP iiD BT
Post #416833 6th Dec 2016 8:24am
Weegie
PS. I have just looked at the first link and it states MPEG4 so should work in France. Wink
I still have my analogue tuner as well as my digital so will give it a go. Thumbs Up
PPS. "Not suitable for MOST (touchscreen) systems". Back to square one. Mr. Green John
GAP iiD BT
Post #416883 6th Dec 2016 3:21pm
kalachnikov
Switzerland 2010 Range Rover Supercharged 5.0 SC V8 Bonatti Grey
French TV
Hi,
I have a L322 from 2010 and I'm trying to sort out the French TV issue. I get the Swiss channels but not the French.
I just came across this thread and was wondering whether the problem was not the digital versus analog in my case. I may have the digital tv but not able to read HD as all the french are in HD.
What do you think or am I speaking nonsense (I'm not a techie) ?
Thanks
Pierre
Post #443982 8th Jul 2017 10:34pm
Weegie
Afraid that's the problem. The digital decoder is SD only. The OP is trying a different set up. John
GAP iiD BT
Post #443991 9th Jul 2017 7:07am
kalachnikov
Hi Weegie,
Thanks for the reply. What does the "OP is trying..." mean?
Pierre
Post #443993 9th Jul 2017 7:12am
Weegie
Pierre, The Original Poster is trying to use a different TV decoding set up. See the first post in this thread and his, later, explanation of hat he has done.
As far as I can see, it only works on the earlier cars.
Regards John
GAP iiD BT
Post #443995 9th Jul 2017 7:17am
kalachnikov
Thank you John.
Matt, thank you for the information you gave in this thread, unfortunately, not being a techie...
Few questions if you have a minute, my car is a 2010 L322, with touchscreen on the front and rear entertainment system at the back. I can watch swiss channels but not french (tnt) my tv won't even find them in blurry mode or something. Just no french channel at all:
- It seems my system has originally a digital tv?
- Would it be that I can't watch the french tv channels because they are HD (check weegie's reply)
- Do you have any idea on how to upgrade the 2010 multimedia so that I can watch french tv?
Thank you
Pierre
Post #444000 9th Jul 2017 7:36am
p38arover
Australia
I did the same mod last week.
Now to install the PiBUS media centre kit I bought from the same bloke in Australia. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #447897 15th Aug 2017 5:53am
