Home > Technical (L322) > vogue central locking faulty....not the key!
billsmith737
England 2009 Range Rover Vogue TDV8 Santorini Black
Hi all, im new here and to range rover ownership. ive just bought a 2009 vogue from a scum bag dealer thats told me to sod off after i called HER when i got home with the car to say the key didnt lock or unlock it, drives fine
Had the key checked out and its fine, tride some of the re-coding procedures ive read on line and nothing works, it appears to be the car at fault.....any ideas where to start checking??
Cheers..
Post #416484 3rd Dec 2016 6:30pm
Usually it's the key, not the FF, what makes you think it's the FF...??? Pete
Post #416528 3rd Dec 2016 11:06pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Based on past experiences, it could be the car but I think the L322 works slightly differently, hard to tell without it in front of me.
But basically I've had cars where the little flap in the ignition barel was stuck open, and the car thought the key was in therefore central locking didn't work. Used a bit of graphite spray to loosen it up and it worked fine ever since! Worth a look ?
Post #416535 4th Dec 2016 6:18am
billsmith737
i took the key in for repair, he tested it and it was sending the signal fine....
Post #416547 4th Dec 2016 10:25am
billsmith737
it registers the key being put in and taken out fine, if it was stuck wouldnt it beep all the time telling you youd left the key in??
Post #416548 4th Dec 2016 10:26am
CS
I wonder whether the problem might be with rear door locks being sticky, I had that problem with one of mine. Only Range Rovers since 1988
Post #416731 5th Dec 2016 12:19pm
They do sometimes lose the sync with the car, maybe reprogramming them would help....
Not sure how you do it on your year though.... Pete
Post #416789 5th Dec 2016 8:23pm
There is a way to do it, I agree with Pete it sounds like the key has lost sync.
It's on here somewhere,
Have a read here and try the methods shown
http://www.fullfatrr.com/forum/topic3713.html?highlight=key+sync There is nothing that can't be fixed with a hammer😜😜
Post #416790 5th Dec 2016 8:34pm
billsmith737
ALL sorted now guys.....many many attemps at the re set procedure finally paid off!!
cheers.
Post #417212 8th Dec 2016 10:52pm
