![]() | Home > Technical (L322) > pcv valve queries.. |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
I used a mechanics board to lay across the engine, it's much easier than kneeling believe me.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Great..that's all I needed to know |
DoubleRL322 Member Since: 05 Jul 2016 Location: Orlando, FL Posts: 25 ![]() ![]() ![]() |
Some people have stated they had Torx 30 but mine were actually Torx 27 (25 seems like it will fit however it will strip so beware, 27 is that awkward one in the middle which is usually left out of the sets). Also, I think they are actually Torx + not regular Torx so you should have less of a chance of stripping them is you use a Torx + bit. Also, there are two on the bottom which are very hard to reach with a regular socket wrench. There is not enough clearance with the back coolant lines. I got a regular wrench with a rachet end and put a torx + bit in it in order to crack it loose. I replaced all with regular bolts.
Thanks for the write up |
No problem |
Hi alistair,
Hi mate . I'm working alongside a plumber just now...I'm off to check his van for some |
Anything to make the job easier |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 ![]() ![]() ![]() |
Hi.
While your there replace the little plastic water pipe joiner that sits behind the PCV. Mine was leaking a little, think it's common. Easy to do while there and only about £10 2003 4.4 Adriatic Blue FF |
Hi Lee, did you replace all 4 hoses or just the top two?
Hi.
