Home > Maintenance & Mods (L322) > Coolant change on TD6, should I flush it through as well?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Am thinking its been a while since the coolant was changed, is it a simple DIY job or should I get my local guy to do it for me? If I do, how long a job is it?
Post #416449 3rd Dec 2016 2:28pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
ive always had mine done at main dealer but ive changed on a bmw 730 same engine easy job but getting air out can be a pig if is same as bmw get a couple of the blled screws was only a couple of quid at bmw spares
Post #416453 3rd Dec 2016 3:30pm
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
Easy job
Drain screw on lower edge of radiator
3 x bleed screws
1 on EGR heater/cooler
1 on metal pipe just to the right of EGR bleed screw
1 on expansion tank 2009 - L322 5.0 S/C Autobiography
Post #416479 3rd Dec 2016 6:18pm
mrblonde
Very very belated thanks guys Embarassed (as per my other post, I've now got free time so doing all the overdue jobs)
Should I flush the system through when I do a coolant change? If so, how?
Or just let it run dry, then top up with the new pink stuff? (50/50 mix with deionised water)
Post #490313 29th Sep 2018 1:57pm
