Home > Technical (L322) > 020 Battery fitting
cass
020 Battery fitting
Has anyone had any luck fitting a 020 AGM battery to a 2011 TDV8 ?
Since I got the car 6 months ago I've had the "low battery" message on odd occasions but as it started fine after standing for 3 weeks when I was on holiday and there were no other problems I wasn't concerned.
As the car is now 5 years old and looks to have the LR/Varta original AGM 95Ah battery fitted I want to change it (I see batteries as a consumable and think 5 years is enough - it's not a lot of money to buy some peace of mind!).
I fitted one to my previous 3.6, it was a bit tight but it went in but this looks tighter again, searching the forum and asking around plenty of people seem to think that it "should" fit but I can't find anyone who "knows" that it will.
If anyone has done this could you advise which make of battery it was as I suspect there will be very little between one that will fit and one that wont.
I don't mind lots of unbolting things to get it in but I'm not keen on chopping lumps off the battery or car, I would hate to buy a 019 if the 020 would fit or even worse buy a 020 and not be able to get it in!
Thanks
Post #416297 2nd Dec 2016 1:29pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I have bought an 020 to go in..I will let you know how I get on.
Post #416345 2nd Dec 2016 6:04pm
Mikey
I have also bought an 020, and fitted it. Unfortunately, the battery terminal wouldn't fit. Seems the 020 is too long... Big Cry
For reference, it was an Exide AK1050 (or EK)
Post #416377 2nd Dec 2016 9:14pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hallo together, at 2011 4.4TDV8 313hp fixed this one: http://www.ebay.de/itm/371034812384?_trksi...BIDX%3AIT, only problem is the ECU box, one screw, 30 minutes, and in time of changing I give 12V to the car with externe battery..., best rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #416382 2nd Dec 2016 9:40pm
Mikey
That's not the correct AGM battery
Post #416409 3rd Dec 2016 9:03am
cass
Thanks gents - one says yes (even if it isn't an AGM) one says no so I'm still just as confused Laughing
If someone with the experience of Mikey couldn't make it fit I doubt I'll have much chance. It's all down to Rambles now, if you can make it fit I'll give it a go, if not I'll have to settle for a 019.
Thanks again for replying.
Post #416465 3rd Dec 2016 4:55pm
Rambles
Ok. I have set aside the 12th to have a go. (I am working in Amsterdam next week).
Expect feedback on the 13th.
Post #416469 3rd Dec 2016 5:27pm
Mikey
Th battery dimensions seem very critical. 350mm long is around the max, and an 019 fits the bill perfectly
Just need to find one with a higher rating than the JLR offering Whistle
Post #416507 3rd Dec 2016 8:21pm
Rambles
393 mm is the length of the 020.
I guess I will be sending it back if too long.
But it is the same dimension of the regular lead acid people install in pre AGM FFRRs.
Many have successfully installed these.
http://www.puredrivebatteries.co.uk/h15-va...ttery.html
Post #416544 4th Dec 2016 9:53am
had a look at the bits bolted to the battery today.
it seems pretty much the same as the 3.6? in which case i managed to get an 020 size to fit by cutting off the bottom end bracket with a handsaw. Went in fine then.
Dont forget according to the WM the car needs telling if its had a new AGM fitted regardless of wether it has had one in previously. There is nothing that can't be fixed with a hammer😜😜
Post #416618 4th Dec 2016 5:50pm
dirtymonkey38
Sorry to keep reviving threads......
Im in need of a battery. Currently has an OEM varta AGM batterry installed, however I can work out what size it is. Been reading conflicting info around what will fit.
Same predicament as Cass, I would hate to buy a 019 if the 020 would fit or even worse buy a 020 and not be able to get it in!
Has anyone had success with the larger of the two batteries?
2011 4.4 TDV8 Autobiography. 2011 RR Autobiography 4.4 TDV8
Post #444290 11th Jul 2017 11:07pm
GGDR
What's the difference between a 019 and an 020?
. Cheers, Greg
Post #444291 11th Jul 2017 11:37pm
cass
The 020 is physically longer and is rated at 110AH, the 019 is rated at 95AH.
I was a coward and took the easy option and fitted a new 019, after doing the job I doubt I could have got the larger battery in without some serious messing about
Post #444292 12th Jul 2017 2:58am
Mikey
I tried the 020 in another FFRR, and it still didn't fit
By this point, it was too late to return it, and seemed a very expensive door stop
So, I took out he 2 month old 019 from my Defender, and put the 020 in its place, and put the 019 into the FF Thumbs Up
Post #444296 12th Jul 2017 6:01am
dirtymonkey38
020 is 40mm longer.
Looks like ill go for the 019 then. The old one im taking out may be good enough to use in a dual battery setup if it will fit in the boot. 2011 RR Autobiography 4.4 TDV8
Post #444313 12th Jul 2017 9:11am
