Home > Technical (L322) > Driver door window not working
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
Opened the window which then decided to close by itself; however half way up it stopped - now it's not moving at all, though there sounds to be a clicking noise.
Whilst it was going down I heard some noise - will appreciate some advice regarding what it could be. Does the fact that it make the clicking noise mean that there is power going to the regulator and that the regulator is fubar or should I start by checking / replacing the fuse and the relay
Post #416024 30th Nov 2016 3:40pm
sounds like a 'door card off' to see whats happening.. ... - .- -.
Post #416027 30th Nov 2016 3:42pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
reckon your wire on the Regulator has come off the runner or split. There is also a flimsy piece of plastic that holds the wire end into the regulator and these are known to split and dislodge the wire.
Door card off, have a good look and then get a second hand regulator if required (c. £30-40 in UK)
Easy enough to replace yourself and there are lots of videos to show you how. Thumbs Up
Post #416031 30th Nov 2016 4:51pm
vnitos
took the door card off and found that one of the cables have broken.
now what to do - does it require a new regulator or can one buy the cables loose
then if one can get the cables loose how do you fit it
Post #416196 1st Dec 2016 5:25pm
Dolphinboy
Don't faff around trying to get a new wire on (even if u can find a new wire for sale on its own they are a b&gger to fit!) just get a second hand regulator from a breaker or eBay for c.£35. Takes about 1-2hours to fit - plenty of YouTube videos to show u how. Thumbs Up
Post #416244 1st Dec 2016 10:40pm
vnitos
thanks will do that
just to confirm - i assume that the regulator comes with all the cables
Post #416257 2nd Dec 2016 3:58am
Dolphinboy
Yes, make sure you get the correct one for the relevant window. They are all different. Whistle
Post #416306 2nd Dec 2016 2:31pm
