![]() | Home > Maintenance & Mods (L322) > Help needed identifying a new noise please. |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
first thing to check is the brake disc protector, a round tin shield on the inside of the disc. The bolts rust away and then it sits loose and makes a horrendous sound.
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836
Hi, it sounds like it could be the outer CV joint giving way, the way to test whether it is or not is to put the steering on full lock and drive in a circle listening for clicking or as you said a crackling sound.
| hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294
Thanks for the replied guys, the brake disc protector is still firmly in place and seems in good condition with little corrosion but will take a better look later.
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
Does it sound like its inside the car? A while ago we had an odd clicking / buzzing noise from the drivers footwell area which came on for a few minutes on startup, turned out it was one of the fan motors giving out and the noise was the fan blades catching on the housing. |
Thanks Paul, that's certain worth a look, as I said, it does perhaps sound like it's coming from the drivers foot well so you might be on to something there.
Outstanding Paul, top of the class and top of my Christmas card list..... I tried it on the way home from work with the fan turned on and off and the short lived mystery is solved. The bearings in the fan must have some play in them allowing the blades to rub against the housing when cornering so I'll have a look at it over the weekend and think about a solution, easiest is probably just to take a little bit off the blades where they're rubbing. Thanks again for the idea........ |
| All times are GMT |
