Home > In Car Electronics (L322) > Timed climate
tvralan
Timed climate
Hi All
I have timed climate which works beautifully when set from the screen in car.
I would love to set it remotely, but don't know how to modify.
Is it just that i have to get a remote fob and code it to the car?
Its a TDV8 Vogue 2007 vintage.
Thanks
Alan
Post #415464 26th Nov 2016 2:53pm
Weegie
Get a remote. Plenty on E-Bay. You need a T90 or (preferably) a T91. Then pair to the car. Once you have the remote there is plenty of information on the forum re-pairing. Thumbs Up John
GAP iiD BT-Sold
Post #415467 26th Nov 2016 3:23pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Make sure you have the receiver in the boot. I bought a t91 remote and had to then buy the receiver and an aerial 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #415470 26th Nov 2016 5:12pm
tvralan
Thanks for the feedback.
Off to the bay for a remote.
Best regards
Alan.
P.S.
If you look closely you can just see my subtle FFRR sticker Very Happy
Post #415614 27th Nov 2016 7:07pm
rob8420
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Hello
I was just looking in the boot of my ffrr and see that I have a receiver which says t91 on it.
I wondered do I just need to get a remote? How do I know if I need anything else?
Thanks
Robin 2011 FFRR Vogue SE Stornoway Grey
Post #415772 29th Nov 2016 12:25am
Weegie
Just the remote then pair it to the car.
http://www.fullfatrr.com/forum/topic22743....ing+remote John
GAP iiD BT-Sold
Post #415791 29th Nov 2016 9:30am
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
not sure if you need anything else but I noticed you can set fbh by an app on webasto site
Post #415798 29th Nov 2016 11:31am
rob8420
Thanks for that I will have to get that done Thumbs Up 2011 FFRR Vogue SE Stornoway Grey
Post #415917 30th Nov 2016 12:35am
tvralan
Hi All
Got my T91 remote and have tried all sorts to sync but no luck.
The only thing left is to remove the feed to the little box inside the O/S rear wing.
But can I get the plug out!
Any tips for removing this little critter would be more than welcome.
Thanks
Alan
P.S. Its the little plug top right.
Post #417591 12th Dec 2016 3:52pm
Weegie
Yes it is a bit of a "B" to unplug. I had to unbolt one side of the plate in front of it which then swung out of the way which meant I could unplug it. You may have to unbolt it all but it was the only way to get sufficient purchase to unplug it. It was also the only way I could get it to pair.
Good luck. Thumbs Up John
GAP iiD BT-Sold
Post #417594 12th Dec 2016 4:49pm
