Home > Technical (L322) > air suspension locked |
reynolds Member Since: 07 May 2010 Location: great yarmouth Posts: 83 |
Any help please my 2004 range rover" air suspension inactive warning "has come on no speed warning also the suspension lock light has come on preventing adjusting it any advice much appreciated. |
4th Dec 2010 9:16am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
first thing i would check is the battery, if its over 3/4 years old it might be failing... ... - .- -.
4th Dec 2010 12:09pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Start up and turn the wheel all the way to the left then all the way to the right and should clear the fault. |
4th Dec 2010 12:24pm |
thanks for advice battery is 6 months old i have turned steering wheel lock to lock disconnected battery fault still there any more help much appreciated does any one no where the obd port is located on 2004 diesel autobiography |
5th Dec 2010 11:54am |
obd port is on the lower right of the dash by the door. ... - .- -.
5th Dec 2010 12:09pm |
Same place it is on every L322. In the coin tray by your right hand knee when sat in the drivers seat... I have one of these: http://www.rswsolutions.com/index.php?opti...;Itemid=77 and it's a lot of bang for your buck! |
5th Dec 2010 12:15pm |
thanks for advice had it checked at garage pump nfg hope that cures it |
7th Dec 2010 8:59am |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 |
Let us know if sorts it. having similar issues!! |
8th Dec 2010 8:49pm |
yes all sorted |
8th Dec 2010 11:53pm |
How much was the pump and installation?? Did you have any issues raising/lowering the car prior to fault?? |
12th Dec 2010 6:18pm |
hi it cost just under £500 inc fitting and programing i was advised not to keep lowering and raising vehicle as it causes premature failure as car is very heavy for the size of pump |
13th Dec 2010 4:30pm |
Fr_Raf Member Since: 20 Nov 2010 Location: Lyon - Paris Posts: 147 |
I have had the "air suspension inactive" for few weeks.
23rd Dec 2010 9:30am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
I'm still waiting on my EAS activate, left USA on the 29th November...Bloomin snow!!!
23rd Dec 2010 10:11am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
I have had similar messages recently after being in deep snow but they tend to clear after a while with an ignition off/on.
23rd Dec 2010 2:11pm |
