Home > Maintenance & Mods (L322) > 2010 -> Workshop manual.
Page 1 of 8 12345678>
Has anyone found a 2010 on workshop manual?
am trying to eradicate a squeaky belt pulley and want to replace the belt first to see if that is at fault, space is limited and not sure what needs to come off to do it. Im assuming that the viscous fan and shroud need to come off. but other than that i can't really see anything else in the way.
Im thinking that it will be much the same as the 3.6. though not sure exactly what is squeaking. It goes after a short while and I'm thinking when the belt has warmed a little, as i doubt the pulleys would stop squeaking if they were gone south. squeals like mad if you wet the belt then goes quiet and the squeak stops. There is nothing that can't be fixed with a hammer😜😜
Post #414401 19th Nov 2016 6:39pm
been looking for a while but its only available on topix for which you have to subscribe to... ... - .- -.
Post #414402 19th Nov 2016 6:44pm
Baltic Blue
Stan, I am sending you a PM.
Post #414422 19th Nov 2016 8:37pm
i see that you have sent me my homework for the week Mike... Shocked Shocked Laughing ... - .- -.
Post #414494 20th Nov 2016 11:34am
Baltic Blue
Let me know if you want me to send you a blank DVD Stan.
Post #414497 20th Nov 2016 11:41am
i'm ok for those Mike, i'll pm you when i get it all burned.. ... - .- -.
Post #414498 20th Nov 2016 11:42am
Baltic Blue
NMJ,
I think I would try spraying some belt conditioner first to save a lot of work.
Search eBay squeaky belt spray.
Not much to loose, less than a fiver.
Post #414500 20th Nov 2016 11:55am
top tip I'm off shopping now. Im thinking belt rather than pulleys. as when the tension was off there didn't seem to be any issue with them they moved freely (well the ones i could reach in anycase) Thumbs Up
Edit - you guys found a rave solution?? Bow down Bow down Bow down Bow down Bow down Bow down There is nothing that can't be fixed with a hammer😜😜
Post #414558 20th Nov 2016 6:53pm
mjdronfield
I too would be interested in a RAVE solution Whistle 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #414573 20th Nov 2016 9:14pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
+1, please.
Post #414595 20th Nov 2016 10:50pm
Mike [baltic blue] has downloaded some sections of the WM, mainly the 4.4 info but there are parts that are still needed , so if any one can supply these i can add them to what we have ..
unfortunately the page links dont work so i have put the info into relevant sections.. ... - .- -.
Post #414635 21st Nov 2016 12:42pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Hi Stan
I hope to spend a day doing the same as Mike and I have a PM about whats left to do.
I probably wont get round to it until nearer xmas though. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #414687 21st Nov 2016 6:34pm
thanks Ade, i've had stuff sent to me from 'nino nino' which i need to sift through.. ... - .- -.
Post #414700 21st Nov 2016 7:13pm
Baltic Blue
Stan,
A quote from the Duke of Wellington comes to mind.....
Publish and be damned. !!
Post #414716 21st Nov 2016 8:57pm
Post #414722 21st Nov 2016 9:22pm
