Home > Technical (L322) > Compressor or EPB fault ?
n1cktdv8
I've done some reading and searching folks but here's the symptoms...
Not driven FF for a week. I never use the EPB. Drove it on Friday and on arrival at work the smell from the rear end was awful. Like hot metal, or a welding workshop !
Checked suspension as thought it could be compressor...all good there. It had new brakes in the summer and the rears are now squeaking (genuine LR all round).
Could this be a binding caliper or the EPB?
Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #414571 20th Nov 2016 10:06pm
did you touch the wheel to see if it was hot [sticking caliper] ... - .- -.
Post #414579 20th Nov 2016 10:29pm
Sounds like a sticky calliper to me.
As Stan says check for cooking hot brakes after a run. The usual fix is a new calliper, but the cause can be as simple as a corroded calliper carrier which traps the pads. Can be fixed with a file to the calliper carrier behind where the pads sit in the stainless clips. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #414583 20th Nov 2016 10:53pm
n1cktdv8
Right hand side wheel hot, near side cold.
Caliper it is I think chaps, appreciate the replies. Caliper is cheaper than a compressor ! Is this where I put the car details and a bit about myself ?........
Post #414587 20th Nov 2016 11:08pm
Strip the brake down and check the pads aren't stuck first. If they are a PItA to get out then the carrier is corroded. It's generally only surface rust and a good clean up may sort it before you invest in a new calliper. There is nothing that can't be fixed with a hammer😜😜
Post #414588 20th Nov 2016 11:12pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Doesn't the EPB engage automatically after ignition off anyway so could it be that after all? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #414690 21st Nov 2016 7:43pm
