Home > Technical (L322) > glove box light
alistairh
glove box light
Trivial question tonight but I've lost light to the glove box light, passenger door handle light ...fault readers showing a fault in the bcu saying its a faulty fuse. I have the electronic library in my iPad at home but I'm miles away and my OCD is telling me to check it now Banging Head I presume a bulbs went in one if the "dark" areas and fused the one side?
Anyway could anybody shed some light Laughing As to which fuse to check Laughing
Post #414561 20th Nov 2016 7:18pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
See if this is any use:
INTERIOR ILLUMINATION
DESCRIPTION
General
Operation of the interior illumination LED's and lamps is controlled by the Light Check
Module (LCM). The LCM is located at the base of the RH 'A' post, and powers the LED's and
lamps when the ignition switch is in either the auxiliary or ignition position, and the lighting
switch is in either the side or headlamp position.
OPERATION
Power Distribution
Feed from the positive battery terminal (C0192) is supplied to fusible link 3, fusible link 4,
and fuse 53 of the passenger compartment fuse box (C0632) on an R wire. Fusible link 3
(C0589) and fusible link 4 (C0590) provide constant battery feeds to the LCM on R wires.
Fuse (C0583) provides a constant battery feed to the ignition switch (C0099 on Td6 vehicles,
C0028 on V8 vehicles) on an R wire. When the ignition switch is turned to the 'auxiliary'
position, current flows across the switch (C0099 on Td6 vehicles, C0028 on V8 vehicles) to
fuse 9 of the passenger compartment fuse box (C0585) on a PB wire. Fuse 9 (C0587)
provides an auxiliary ignition feed to the LCM (C2040) on a PY wire.
When the ignition switch is turned to the 'ignition' position, current flows across the switch
(C0099 on Td6 vehicles, C0028 on V8 vehicles) to fuse 4 of the passenger compartment
fuse box (C0585) on a G wire. Fuse 4 (C0587) provides an ignition feed to the LCM (C2040)
on a GS wire.
Lighting Switch
The LCM (C2040) monitors the condition of the fascia mounted rotary lighting switch
(C0041) by providing a feed on an NB wire. When the lighting switch is turned to the side
lamp position, it returns a feed to the LCM (C2040) on a Y wire. When the lighting switch is
turned to the headlamp position, it returns a feed to the LCM (C2040) on a B wire. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #414566 20th Nov 2016 7:54pm
alistairh
Thankyou Thumbs Up
Post #414569 20th Nov 2016 8:27pm
