Home > In Car Electronics (L322) > TV update and reversing camera
Clivefog
I'm considering £300 to supply and fit a reversing camera and update screen to display and also show TV.
Is this a good price? Please hold in mind that my soldering looks like welding and is often a failure hence handing it over to someone to do.
L322 03 with as far as I know all original electrics.
Post #414386 19th Nov 2016 6:07pm
thats a lot of money for something you might not use, the tv i mean.... ... - .- -.
Post #414446 19th Nov 2016 10:55pm
If its a decent quality camera, well fitted and automatically switched the TV when you select reverse, then it's not too bad.
I did mine many years ago - you could buy a connector that fitted in line with the units in the boot, but needed a +12 supply and also to tap into the reverse light to switch the picture over. All fairly straight forward as it's all in the boot area anyway.
Installing the camera and getting the cable into the boot area is a little more tricky.
It's probably a couple of hours work plus the parts - so if it's a neat job, £300 seems fair IMHO.
Post #414467 20th Nov 2016 9:18am
Clivefog
I'm not worried about TV. I just want to be able to see when hooking up a trailer, ok with my folding camper it has motor mover installed, car transporter is very hit and miss and way to heavy to man handle when loaded.
Yes it will auto switch when selecting reverse and auto disconnect when trailer electrics are sensed.
I think I'll go for it, £300 would cover the cost of wrecking the bumper, I've come close! And no I do not want TV on the move.
Post #414486 20th Nov 2016 11:40am
